Barometric Pressure sensor voltage low code?
bryceraisanen
988
177
Got an almost brand new 2021 850 Khaos with silber running 7 lb. Got about 100 miles on the sled.
In cooke city today, was getting DET quite a bit and then got that fault code at end of day. Sled was running rough once the fault appeared.
Anything I can do to address this fault?
  • Like
Reactions: Aksnowchaser
sledhed
1,752
435
83
Lolo, Montana
Running the correct intake temp sensor? Needs to be the blue Bosch not the stock silver labeled one. Sensor might be bad too.
bryceraisanen
988
177
Update. Found the issue.
The throttle cable was routed so that it was rubbing against the wiring coming out the back of the tmap intake sensor. The coating was worn thru a teeny bit on the blue wire. Zip tied the throttle cable a bit to the side, taped the wire and everything ran fine.
Sent from my SM-N976U using Tapatalk
bryceraisanen
988
177
Are you talking about a blue sticker or the sensor itself is blue? Is there a thread or explanation of this?
I think the sensor is black, with a black/white sticker on it.
