Bark Busters on 09 700 RMK
This may be old news to some, but just wanted to let those that are considering Timbersled's A-Arm kit for their IQ chassis sleds, that these will not accept the std RMK rear mounted sway bar design. They can be adapted to work with the 09+ front mounted sway bar design like on the Dragons).
So I will be running w/o a sway bar and will initially set my Float2s at 70psi. Allen from Timbersled recommended 80psi but he did so without know my weight (around 195 to 200 w/gear).
For those that did remove the std RMK sway bar, did you block off the holes in the belly pan or just leave them open?
