C
catweasel
In my quest to put the big Cat on a diet, I decided to try the Ballistic Battery. I was shocked at how small and light it is at 2.44 pounds. When holding it, it is feather light. The stock battery has to be over 10 pounds easliy. I left it outside for a few days to see how it did in the cold. It was 9 degrees last night so I went ahead with the install. Here is the battery-
http://www.ballisticparts.com/products/batteries/12cell.php
More CCA than stock and gauranteed to work down to 0 degrees.
It is not a striaght foward install. I had to make some modifications to make it fit right.
I saw someone back in December install one and the wrapped it in aluminum foil. Nothing against them, but I would never wrap a battery in conductive material. I ordered the foam insert for an extra 7.00.
First I set the battery in the foam and cut the foam down till it was apporximatly the size of the stock battery. I then ran into my first problem. The terminals on the new battery have a small plastic trim on the inner and top sides. The aluminum plate would not sit flush on the battery or clear the terminals. You can't turn the battery upsidedown because the cables are way too short. I ground these off.
I then ran into my second problem. The aluminum plate that secures the batter touched the terminals on both sides since they are much closer together than the stock one. Sparks did fly. I took an angle die grinder with a small grinding wheel and ground down the sides till I had 3/4 inch clearance on both sides.
Got everything hooked up and ran into problem number three. Since the terminals are closer, they line up with the bolts that hold the aluminum plate on. The terminals were too close to them for my liking. I cut about a 1/2 inch of foam off the bottom of the insert so the battery would sit lower, giving me about 3/4 of inch clearance on the bolts. I took some of the foam I had cut off and glued it to the bottom of the aluminum plate to secure the battery. Bolted everything down, installed the seat, and she fired right up.
187.00 for the battery and 7.00 for the insert for a 10 pound diet. Not bad.
![IMGP3105.jpg IMGP3105.jpg](https://www.snowest.com/forum/data/attachments/134/134391-9d460fff57da7ac1be31bad0e4079c8c.jpg?hash=nUYP_1faes)
![IMGP3103.jpg IMGP3103.jpg](https://www.snowest.com/forum/data/attachments/134/134373-36c3bf1a080fdda0ead270c9acccdce8.jpg?hash=NsO_GggP3a)
![IMGP3104.jpg IMGP3104.jpg](https://www.snowest.com/forum/data/attachments/134/134383-6f5214d7319677d6eb5c5156e234bfc2.jpg?hash=b1IU1zGWd9)
