Bag Comparisons
New Enduristan Bag Arrived.... Will show on yeti rack once it’s delivered.
Did a comparison to Mountain Addiction and Timbersled bags
Mountain Addiction
Pros
Dam tough bag... used on most of our tour bikes.
Good structure.. not floppy.
Rock solid tunnel attachment.(for Timbersled!)
Cons
Painful to take on/off the bike... takes some serious effort. Consider it permanently attached to the bike!.
Would take some modification to use on yeti rack
Get water logged and takes a bit to dry out.
Difficult to clean inside. (Incase some idiot puts a banana in there or forgets to lock the thermos top!.)
Timbersled Adventure
Pros
BIG... Looks good..! and easy to removed /attach.
Could use clips and make strap to fit yeti rack.
Cons
Requires brackets to be mounted permanently on the tunnel.. (Timbersled)
Brackets are very poor design imho and make this bag useless.
Top isn’t well sealed... expect powder snow inside your bag if you lay the bike over.
Timbersled/ Yeti Logo Mismatch.
Unused... but probably a wet bag versus the rest
Timbersled Small? Bag
Pros
Small light, quick on / off. Cheap!..
Reasonably water proof .. very easy to dry overnight.
Cons
Very Small!.. Timbersled / yeti logo mismatch!
Moves around a bunch and rubs paint off tunnel!
Enduristan Bag
Pros
Low profile, mid size bag or large!... depends what you put in it how effective the space is.
Material & zipper looks very water tight looks very easy to dry out quickly.
Cons
Low profile shape makes space usuage less versatile
Slightly floppier then the rest of the bags.
Metal hooks - good or bad no idea yet... but easy to remove and just use the strap.
