Back firing problem!?
OK i just got don't with a full day of boondockin, and when you strat my sled up and take off gently it back fires once but not real bad. The plugs are not whet but a little darker and its 20 degrees here in Michigan. :face-icon-small-fro
could be a bad plug, or soon to be fouled plug..or poor TPS setting..
its not that uncommon to get a pop now and then..happen to me this weekend..i had to replace the plugs, then i was off..
could you start it and ride after?
if so..i wouldnt sweat it...check/replace plugs...ride on!
Exactly what I was gonna say, I had a little back-firing when I started mine yesterday. After I heat-cycled it the first time I was trying to loosen up the track when it started popping a little. Heat cycled the second time and went to leave and it gave a big pop, died, and would not stay running after that.
Changed the plugs and it ran fine all day and still is. Old ones were not fouled just a little dirty and oily. Cleaned them up and they are my spare spares. Probably from premix and oiler bleeding for me.
