Axys tunnel reinforcement.
sledheadd
Are the Axys tunnels stronger then the Pro tunnels?
I always carry fuel and about a 10lbs tool bag and on my Pro the tunnel got bent and cracked the first time I jumped it on setup snow.
My new sled will be a 174" and nobody has any braces out for it yet.
Regardless of track length I'd like to know what braces have you been using on the Ayxs.
Thanks
This is what's on my pro 2 layers of reinforcement on either end and one in the middle.
Unfortunately the guy who made these doesn't make them anymore.
Greer tank is still in business.........
Mike just drew what he wanted and had a local waterjet cutter "make" them.
You can do the same with a little legwork.
He just gave them a paper template and they generated the cad file.
Yes they will,
I should of been more specific. I am looking for rear tunnel braces, from the boards to the back of the tunnel.
I don't know if Paul (Fire n Ice) checked to see if the 2 versions of his rear tunnel braces will fit the '17 174. The drop brackets are further back and the taper of the tunnel side may be different. I'm sure he'll have something before it snows this fall.
