So I read through SRXSrules thread (https://www.snowest.com/forum/showthread.php?t=404826) on TPS ajustment which I believe was originally written for the Polaris Pro (pre axys) sled. I have a 16’ stock axys and a 17’ with boondocker sidekick turbo. The stocker starts easily the first pull, but idles at 2300 rpm. The turbo takes 3-4 pulls to start with some throttle to get it going. So I wondered if adjusting the TPS would help. I really wanted to see how easy it would be. Was not looking forward to tearing the whole sled down like intructed in the write up.
Axys BD sidekick was a breeze. All I had to do was pull the side panels, hood and secondary clutch to access the 8mm lock nut and 2.5mm screw for the idle. Literally takes only these two tools, 8mm box end wrench and 2.5mm driver. It’s very easy to access the lock screw from the clutch side of the sled with the secondary removed. The 8mm box end is accessed from the top and the Allen screw from under the airbox from the rear. See pics. Literally took about 30 minutes to do the entire precedure following the srxsrules instructions for adjustment.
