Its no BS at all... not at all. Your naïve if you think is its BS....
Its pretty simple math dude.
At 8000-10000 feet your stocker is down about 30% on power from stock.
a turbo sled at 7psi is putting out roughly 20% *more* than stocker (at sea level) at the the 8-10K elevation range. That is a massive delta delta in power (down 30 vs up 20). If you aren't getting belt slip, you are getting shift out, etc - well, I'm sorry but I don't see your "perfectly clutched NA sled" making up for that big of a horsepower delta....
EDIT: Even at 5psi its a massive delta.
One big problem with a poorly clutched Axys Turbo is how many belts you will blow up from overheating them. A proper clutch setup can pay for its self pretty quick
TRS clutching already paid for. Your only as strong as the weakest link
You SHOULD NOT run delrins in your primary. It affects your spring rate and can bind. You should just clean up the spring faces and clutch faces. At most use a thunder products glide washer.
You can run the math all day long. I don't need the math. I have the experience.
I am talking typical riding... Most of us are in and out of trees anymore. The set up you listed. Someday someone will pull up with a PROPERLY set up stocker and make you think WTF just happened.
And I could careless if you believe me or not.
Upped the weight in the primary, now at 78g. Sled pulls about 8,100-8,200 @6k'... I was hoping this would lower the heat from the primary..
I'm running the Gates Carbon belt (Axys specific)... after some long hard pulls, the the clutches & belt are hot as hell...like, burn my hand hot.
Ugh. I'm at a loss.
Ugh. I'm at a loss.
You are getting belt slip in the primary and secondary. Poor clutching or..... Where did the water come from? If your belt is getting wet it won’t last long.
