R
Ratchit
ACCOUNT CLOSED
There is documented proof that a belt does not fix all of the low rpm problems. People have swapped belts, clutches, ecu's , checked alignment and deflection and it had no effect. Either one of those has solved the issue for many people that had a low rpm issue but for the people where their rpm drop off like a lightswitch and the tone of the engine changes, it has not helped. What makes it harder to troubleshoot is the fact that it is an intermittent issue where the engine runs like a raped ape one minute, a turd the next minute and during a day of riding, it can go back and forth. That is what people are talking about when they say "rpm fade". Almost like the ecu goes into some sort of protection mode from time to time and there are no check engine lights or dtc's associated with it.
Internet chatter doesn't make it documented proof,hahahaha
I'm glad you believe everything you read on the internet
