L
LOLO21
New member
I have a problem with the dragon mod, it doesn't work, I tested the wires, nothing cut, the button works, once pressed it passes. I have the 5v power supply on the gray wire of the button, once pressed it sends the 5 volts on the black/blue wire.
On the diagrams the black/blue wire is a ground, I do the continuity test between the chassis and the black/blue wire it goes well once the plug of the ECU is connected, I don't understand why once the dragon button pressed it therefore sends the 5 volts of the gray wire into the black/blue wire which is a ground can this come from this?
My colleague told me to check that the exhaust probe was working well, I tested the probe for no resistance while on the manual it says from 6 to 12 Mohm, I think it works because the temperature rises with the engine on.
If you have an idea, the 3 dragon mode lights do not light up on the cluster and it goes away instead of delaying the ignition.
