Axys Primary removal ???
I was a little leery of using heat and have never had to, so for those of you that do, heat gun or small torch????????
heat gun while under pressure.
I also made a hydraulic puller by finding a bolt that threads into the clutch, drill a hole length ways through the bolt, weld a hyd fitting to the bolt head and hook it up to a porta power cylinder, works slick.
