I was just curious if anyone else has had any issues with getting their primary clutch off of an Axys???
I've got a 2017, with just this last season on it and I tried to get the primary off and well.......not happening????
I first tried the puller.... no luck
Then the puller with some taps..... no luck
Next was the puller with a little bit of grease on the end....no luck
Then the tip of the puller bent?????
Next was the water method with the puller but the tip cut off....no luck
Next was the primary bolt and the water method......no luck
It seems every time I use the water method, it gets super tight and then all of a sudden I start to get the water coming back out the hole and I loose the pressure? It's like the pressure builds and then it finally slips by and it won't work. I've wrapped the threads with a ton of pipe tape and still no luck!!
I guess I've never had one this stubborn before and was wondering what else to try besides and friggin trip to the dealer as it's under warranty........
Thoughts ????
Thoughts ????
