Taller lugged tracks are likely not helping clutch longevity either. Over the years traction has increased, engine power has increased, but the Polaris primary has not seen any radical upgrades.
1. Adding motor mount torque arms from fire 'n ice are huge. If your clutches are being pulled out of allignment abnormal wear will occur. The motor mounts on the Axys are poor to say the least.
2. the new axys motor has a bad harmonic, somewhere at or above 8200rpm and becomes more pronounced with a turbo. Adding or removing weight to the primary will not much change this characteristic of the crank/motor
Sent from my SM-G950U using Tapatalk
I rebuilt a P85 with a SPI rebuild kit once to try and save a few bucks over the OEM rebuild kit, 200 miles later all the bushings and rollers were shot again. Use OEM parts or buy a new clutch if you want it to last is what iv found.
