First thing to check is to make sure the wiring to the switch is not unhooked or loose. Eric
The manual actually says that they won't work at idle. Load shedding relay will keep them off, especially when using high beam light.
My Doo was the same way. Pretty annoying. If it's a cold day my hands tends to get cold when first taking off. I liked the Pro having warm grips by the time the engine was warm enough to take off.
Sent from my SM-G900V using Tapatalk
I have owned three RMK's and I've learned that the handle bar heaters simply do not adequately heat the grips when riding with medium insulated gloves and riding the trails at 30 + mph getting to our off trail riding areas in the mts. MY SOLUTION FOR THIS IS: 1. Remove the grips using low pressure air (10 to 15 #) to help remove and preserve the factory grips. 2. Then carefully pealing off the heater elements. 3. Then wrapping 1 / 16 inch thick gasket material with sticky backing on the bare aluminum bar area where the grips were ( buy from NAPA ) 4. Replace the heaters. 5. Put some automotive adhesive used for trim replacement inside the lip of the grip and some on the heaters so the grips can be slipped back on easier and do not slip around. My partner got the adhesive from Hedahls auto supply I believe. It comes in a tube. Sorry I do not have the precise name of it just now as I write but I'll have it soon and I'll update this so you can get the job done right.
I've been suggesting to POLARIS for years that they need to improve the handle bar heaters and the AXYS is still the same as the 2012 RMK. An area that seems to elude Polaris people. What do they expect mt. riders to do wear thick mittens? After all there's no windshield to protect our hands so the only thing we have is the grip heaters to keep our hands warm. Da
I have been sledding for 5 days in the mountains now and they don't work at all. Also, my high beems are not working either. Pretty disappointing. Sounds like a problem with the load shedding relay like you mentioned. Gonna take it to my dealer this week. Other than that the sled performed amazing.
Greg,I have been sledding for 5 days in the mountains now and they don't work at all. Also, my high beems are not working either. Pretty disappointing. Sounds like a problem with the load shedding relay like you mentioned. Gonna take it to my dealer this week. Other than that the sled performed amazing.
Greg,
What were you able to determine was the cause of this issue? My AXYS just started exhibiting the same symptoms.
