Hey everyone,
I've got a 16 axys 800 with a Silber turbo. Sled has 1300 miles on it now, ran great for the first 1000 then broke a power valve cable and it's been having issues since. I replaced the cable and brought it to the dealer to have them relearn the PV positions. I also had them check and adjust the TPS if needed. They said they had to adjust it a little. The sled is now cutting out pretty bad. The issue appears once the sled is hot, really won't do it when cold. Once hot you can get the sled to engagement then back off the throttle a little and it will cut out and almost die, if you hold the throttle still it will continue to do this. I've replaced the 3 relays everyone talks about with no difference. I also located a small nick in a ground wire for the stator (at the plug in the bag by the oil tank) the plug was very difficult to get apart almost melted together slightly. I cleaned this up and taped it but no change. The last ride I noticed my hand warmers were hotter then normal. It is also giving the code 51 10 which states abnormal rate of change for tps. I'm hoping someone can give me some ideas as to where to start. I don't enjoying y chasing electrical issues but looks like I might have to. I need to.start with checking the TPS I'm sure but I have a feeling that's not it with the issue being heat related and the hand warmers being abnormally hot the other day.
I'll try and post a video of what it's doing as well.
Thanks
Thanks
