I realize some things seem elementary and therefore no one posts anything about it, but sometimes guys just wanna see pics or video. So here ya go. Avid Carb Heater Install.
I have the Avid carb heater for the stock CR500 carb. Just attempting to fit the two pieces together showed huge differences in size. The carb seemed too big by a ways for fitment.
The carb has a lip on the intake clamp area that was 0.040" or almost 1 mm bigger in diameter than the fitment side of the avid heater. Anyone else have that much of a difference?
Skeptical I could get that much shrinkage and expansion from the two pieces, I tried the "freeze the carb" and "heat the heater" method. I heated the heater to 500 degrees F in the oven for 30 minutes! Froze the carb over night in ice. No go. Not even close. I tried 3 times. Rubber mallet and all.
So I gave up on that and got my dremel out and carefully ground down that lip all the way around, not completely off, keeping it as uniform and even as possible. I didn't re-measure but I bet the difference now was about half what it was before. Now, when both carb and heater were at room temp, I could at least get the heater barely started onto the carb.
Important side note: You have to have that lip. Or at least I did. The flat area behind the lip (where your airboot clamp goes) was actually smaller by 5 thousandths than the carb heater. Meaning the carb heater would just fall off! So I couldn't grind that lip gone because it was/is the part that'll secure the heater on.
At this point a light bulb went on in my brain as I peered over into the corner of my garage and saw a tool my wife said I would never use and was a waste of money. My press! (To her credit this was the 2nd time I've used it... ever)
So I put wood on both sides and carefully pressed that baby together. It's on pretty darn tight. It might be on for life. But it worked.
I should also mention that I made sure the rotation of the heater was such that hoses would miss the choke lever and clear the top of the carb. I placed a mark on the carb and heater before pressing them together to make sure my rotation was accurate before assembly. See pics.
Clearance to stock shock spring is a few mm (so TSS, being smaller in diameter should be no problem). Clearance to frame is 3/8" or so.
I should mention that this is a 07 CRF450 frame. CR500 motor. But the point of this thread was to just let you know how I got the dang carb heater on.
