Aviation fuel for high miles 700 Edge RMK
I just bought a 700 Edge RMK with high miles and it is not as powerful as I would like. I was wondering if I could run aviation fuel, 100 LL in it to get me through a few rides until I rebuild the top end?
In your situation, the only thing AV or race gas is going to do is lighten up your wallet significantly unless the heads have been changed to increase compression quite a bit. It may even hurt what performance you have as in some instances, jetting changes are required when running that type of fuel. The lack of performance maybe due to the high mileage, ie low compression, weak clutch springs, spark plug wires not making full connection and so on.
We need more info on what you have done to it, fuel filter, spark plugs, belt, clutching and so on.
The only thing I have done is fill it with 92 octane, run some Sea Foam through it and correctly gapped the new plugs that came with it. It runs a lot better now but has significantly less power than my other Edge 700's. It has 3600 miles but has less power than my Edge 600 with 2800 miles on it.
SPI pistons cost less than OEM and the bigblocks are not picky, ran those when I had an '04 Pro-X2 700 a few years ago, ran great...
many times when people think they're sled is down on power it is actually due to dirty or unproperly set up clutches and or worn down or incorrect belts. jmo.
whosthatguy- just throwing it out there that every compression gauge reads a bit diff. 145 on yours might be 125 on mine, or even further off than that. main thing to look for is that both cylinders are close. 145 is a bit much to ask imo, especially at higher elevations.
Last time my sled was not running well, my primary clutch was in need of weight bushings. The old Clymer service manual I had for an Indy 500 said clutching is usually the culprit of an issue too.
I've been interested to know what altitude and at what temperature whosthatguy's 145psi requirement for a healthy motor comes from as he posts it on every engine related thread. My POS compression gauge on my warmed up 04' 800 reads 115psi both cylinders 7200' ~30*F. SLP head and SLP twin race pipes. I've never had it run harder, its not low on power at all.
Compression tests only tell you cranking compression, not dynamic compression that is achieved during running when scavenging really becomes effective, and that's all that really matters. Thats why wild port jobs or switching to twins can lead to low cranking compression but still run like a mutha. Low cranking compression and wicked dynamic compression.
In short, compression tests are good for comparing health of cylinders relative to one another, don't want to see more than a 5% difference between cylinders.
You can also use the test to monitor break in of new rings; immediately after rebuild, haven't run motor yet, comp test will be X. Run motor, comp test gives X+y. Once the value of y stops increasing, the rings are seated. That comp reading is your baseline. In the future, if at the same temp/altitude (read: non-corrected air pressure), the comp test begins decreasing, the rings are failing or your losing comp for some reason that isn't good. Its a good tool to use, but is often misunderstood.
