AV GAS IN WYOMING?
tree climber
does anybody know if any of the airports around the snowies or togwotee will sell AV gas without a tail number
I used to buy it out at the Laramie airport, they put it right in my car. Not sure if they still do or not.
I'm a pilot and have decided to use Race Fuel rather than AV fuel. I believe it produces a better burn. You can also mix it 50/50 with 91. I've used race fuel from Dooley Oil in Laramie for years. Works great and no problems...have used it for years with a Turboed sled. You can either buy it buy the gallon or buy a 50 gallon drum at a discout ( which I do ) and then go see Aden or Don at TrueValue in Laramie (they have a great hand crank pump.
Tell them all I said hi.
Cain
well thanks for that but i can get race fuel here just fine but it sounds like a lot of other people with turboes are running straight AV or even a mix in theirs so i have decided that i want to go that way if i can find a place to get it. here at home none of our local airports will sell unless its going into a plane
