auto tune problem
I have som problem with the autotune..
pro rmk 800 -13 with pa head and slp single pipe..
if I go 12.5:1 in afr on wot the autotune throws in 17% more fuel on top
if i go 13:1 in afr it throws in 12% more fuel and a afr at 13:1 it should be pretty lean.. my basemap is slp stage 3.. I loose about 300 rpm on top if i accept the trims?? if i go back to the stage 3 map the rpms on top are back..
why is it reading so bad? I have a spot down low it will throw in 20% of fuel and if i accept that the sled gets a bad bog down low..
the sensor is located next to the original exaust temp sensor.
I have found the auto tune to be sensitive. The base map i got from bikemen seem to work good. I'll tune on auto tune when i'm on the trail at a constant speed just to check what is does at crusin speed or once up in the hills all turn it on if I do a climb and easy into the throttle. I did a bunch of data logging last week but havent checked it out yet. I have 7 days off starting tuesday so ill look at the trim tables as well.
