I have a 07 Apex with the boondocker GT25 setup professionally installed. Only a couple 100 miles on the system and have been running it at 7-8 lbs of boost with 50/50 race fuel at about 5000'. I was climbing some hills and it was running great, turned up the boost to around 10 lbs. Went to climb the hill and as soon as the turbo started to spool up it would totally crap out...popping, sputtering, no power. Stopped and turned the boost all the way down and made another run at the hill...same thing as soon as it hit boost. Even on a flat trail, right at about 6-7000 rpm with turbo just kicking in would do the same thing. Below that rpm it ran and idled fine. My Innovate 02 gauge bit the dust and wasn't working..(constant E5) so I couldn't monitor that. As I fiddled with it on the way back to the truck I found that on my Logic box at every mode the fuel had been completly leaned out. By adjusting Mode 4,5 and 6 as rich as it would go it started running pretty decent. My question is: Does the Logic box ever reset itself? Should I have to set it at full rich to get it to run on boost? Is it defective? The only change I made was to turn it from 8# up to 10#. I know this is kind of wordy but some of you smarter guys seem to like details. Thanks for your help!
