Attitude box 3.25 start up lights
adam5187
Normally I have three yellow lights come on when infirst start it. Sometimes only 1 or 2 will come on. Has anyone ever had this happen? Sled runs great but just kind of wondering. Thanks
i thought it was supposed to scroll from left to right then back again. might check your ground maybe your injector wires too sounds like possibly something is making occasional connection
Seems like mine is different every time I start it. Usually 2 or 3 lights come on right when I start it (not neccessarily the same ones or colors) then it'll scroll the green lights back and forth a couple times then go to a slow blinking green. Always been this way. I think that is normal.
Thanks, mine does scroll the green light as well and it runs good I was just curious. Also rxl my blue light comes on at around 5000 rpm.
Startup Time
I work for Dobeck Performance as tech and R&D.
If you the controller goes to solid green lights at idle once the sled starts up then the controller is working fine. Most of all Dobeck controllers will scroll green lights for 1-5 seconds but that all depends on the code that Attitude, Pure Logic and other private labels define for a start up time.
Give me a call at 877-764-3337 if you are still a little confused.
Chris
