A
Arctic Thunder
After eating a belt I started really looking into my secondary clutching. Here is the story and maybe it will help someone else.
(PS, I sure like that Dayco 1 year $15 replacement guarentee, got my new belt in the mail today, no questions asked)
Anyway.
2009 M1000
Installed a new Twisted Race gas turbo kit this summer. This included all the extra motor mounts and the clutching for the kit.
After eating the belt last weekend I took my secondary off and tore it down. I had both the washers in the helix, had the white spacer on the shaft and the shift assist bearing that Shane supplied with the kit.
I took the spring out and moved the clutch all the way to full shift. I noticed that the belt could fall all the way down into the secondary even to the point the belt would hit the helix. ( I am pretty sure this is what ate the belt)
I pulled the secondary from my 2010 M8 HCR and ripped the secondary apart on it. I put the helix back in with out a spring and it open until the belt just reached the flat surfaces inside the secondary. Right where it should be.
So I started to compare parts. My M1000 helix was identical to the stock helix in every dimension (exept angle of course).
The stock M8 didn't have the shift assist installed like my TM1000.
I noticed the white spacer on the stock sled was sitting ONTOP of the black stock spacer under the spring. And on my TM1000 the white spacer was inside the ID of the shift assist bearing.
So my Tm1000 was over shifting by .153", the thickness of the spacer.
So what I did was left the black stock .153" thick spacer in the clutch, set the white spacer down on the stock spacer, then installed the shift assist bearing. This then would reduce my avalable clearance for coil bind by .153" so I removed one of the two spacers in the helix, they are also .153" thick.
So now my full shift is right where it should be, my clearance for my spring is back to normal and my belt rides in the bottom of the secondary at the right position.
Anyway thought I would pass this along. I know some of the guys with the shift assist have the one with the smaller ID, but some have the larger ID, if the white spacer fits inside your Shift Assist bearing you will over shift.
Thunder
Anyway.
2009 M1000
Thunder
