I probably have missed this somewhere but what turbo kit is the cat running?
Be wary of these claims of 285 hp with just a fuel remap. The sled is running 13 lbs. of boost stock to reach 177 hp. That means your looking at around 24-26 lbs. of boost to even approach 285 hp.
All the boost guys should know that little turbo will not efficiently push those kinds of numbers, (and who knows about the motor) without building excessive heat, especially when pulling 1000 vertical feet in 3 feet of fresh. It's as simple as that.
....Just like any high hp mod, it's going to cost more than people think to build that kind of performance.
I'm not saying it isn't a sic platform to work from.....just trying to keep it real.
I love this Cat turbo, and I have never had any use for cats. I think I might grab one and see what they can be turned in to.
Yamaha has set the bar for turbo sleds, but at a huge cost. Not sure i would want to push that twin too hard with boost, but the racers are running huge boost numbers.
I have a Polaris, so why not add a cat?![]()
had a very long B.S session with a cat dealer last night who's been boosting up the new cats , short tracks of course . the remap will only get you 240 hp . any thing over that and its pretty much a new turbo kit . but there is lots of cool little things you can go to these sleds to make them rock
Thast b.s.
Where running 30lbs of boost on the stock turbo on my buddies sled but that is with a straight exhast and the waste gate shimmed and for 1/4 mile or less pulls.Without shimming the wastegate you can get 26lbs of boost which is right at the 300hp mark.But in long pulls if will throw codes but not effect the sled this for 1/4 mile or less pulls.The in jectors are only good for 26lbs of boost after that they run super lean.You can get a respectable 285hp out of them.Enough with the hear say stuff.
Thast b.s.
all those HP numbers are "BS"
every tech guys with bit hardware knowledge will tell you that you can blow up a engine to 500hp but only for minutes. so i think most of us want to ride their sled for the whole season?
there are serious limits on the 1100 engine, it need serious changes to run that engine save on 240-250hp. rising boost and fuel is not "smart" modding
do not believe all that forum "BS"
