The 17 mountain cat is your base chassis. They will add the new ctec-2 engine in 853cc which comes in 14 lbs lighter than the current suzuki platform. This engine is also about 3" narrower. Running boards are further modified from the mountain cat raised and angled to make them perform narrower on sidehills. Body panels because of the narrower engine and new pipe setup are significantly slimmer both in appearance and in actual measurement (1.95" narrower than the mountain cat at widest point). Overall the plastics, intake, and led lights are 11 lbs lighter than the current setup. TKI is in negotiations to build belt drives for these which if that deal is completed in time is a 9 lb reduction plus another 4 lbs in reduced oil capacity. Because the new engine is so much more efficient the fuel tank was reduced by 1.5 gallons which equates to 12 lbs lost. Snowflap, bumpers, and hardware are shaved for an additional 2.5 lbs lost.
Its not all good news tho. Because of the additional power output from the engine the pipe and muffler did require a little extra material so they came in 4 lbs heavier than the 17.
Total net weight loss of 48.5 lbs. Thats a RTR weight of 508 (20 lbs lighter than the 3" axys). Also because the ecu can be easily reprogramed you can do an pipe kit for just the cost of the pipe and be at 490 lbs ready to ride.
I cannot wait to get mine!!!
