Id say it removes the insides an there is nothing to bounce around in and tear sh!t up........
Ive shot a lot of rock chucks and coyotes and it doesn't do as much as ya would think. I mean don't get me wrong it does a lot.
Go 223 and if your using it for home defence rounds
ALL OF THE INFORMATION IN THIS ARTICLE IS BASED UPON THE PERSONAL EXPERIENCE OF INDIVIDUALS WHO MAY BE USING SPECIAL TOOLS, PRODUCTS, EQUIPMENT AND COMPONENTS UNDER PARTICULAR CONDITIONS AND CIRCUMSTANCES, SOME OR ALL OF WHICH MAY NOT BE REPORTED, NOR OTHERWISE VERIFIED IN THIS ARTICLE. NOTHING HEREIN IS INTENDED TO CONSTITUTE A MANUAL FOR THE USE OF ANY PRODUCT OR THE CARRYING OUT OF ANY PROCEDURE OR PROCESS. THE WRITERS, EDITORS, AND PUBLISHERS OF THIS ARTICLE ACCEPT NO RESPONSIBILITY FOR ANY LIABILITY, INJURIES OR DAMAGES ARISING OUT OF ANY PERSON’S ATTEMPT TO RELY UPON ANY INFORMATION CONTAINED HEREIN.
.223/5.56 Penetration Tests vs.
.40 S&W and 12 ga. Slug
Overview
The research on the penetration of .223 ammunition has been completed. In an effort to make research more meaningful, testing consisted of handgun and shotgun ammunition in the same testing medium. The final results were that the .223 demonstrated less penetration capability than the 12 gauge slug and the .40S&W [handgun round].
Testing Medium
Type 250A Ordnance Gelatin was cast into blocks, 6"x6"x16". The process used is that which is recommended by Col. M. Fackler, Director of the US Army Wound Ballistics Laboratory. This is a 10% mixture, 1Kg of gelatin to 9000ml of H2O. This type of gelatin accurately simulates human body tissue in terms of bullet penetration.
A small piece of wall was constructed to duplicate the standard exterior walls found in [the Pacific Northwest] area. This piece of wall was sheeted with ½" wafer board, covered with a 2nd piece of ½" wafer board to simulate siding. This wall was built using a 2x4 frame and finished on the inside with ½" sheet rock. The interior [of the wall] was lined with fiberglass insulation.
Weapons Used
CAR-15, cal .223 Rem./5.56x45mm with a 16" barrel.
Glock M22, cal .40S&W.
Remington 870, 12 ga.
Ammunition Used
Federal .223 Remington, 55 grain HP.
Winchester .40S&W, 180 grain HP.
Federal 12 ga., 2 ¾", rifled slug.
Procedure
All rounds were fired from a distance of 12 feet. After each round was fired, its penetration was recorded and bullet performance noted. After a bullet was fired into the [bare] gelatin, another bullet of the same type was fired through the section of wall and into the gelatin. This was done in order to determine its penetration potential in the event a stray round were to hit the wall of a building.
Results
Caliber Testing medium Penetration Condition of bullet
.223 Rem. gelatin only 9.5" two pieces
.223 Rem. wall & gelatin 5.5" * fragmented
.40S&W gelatin only 13.5" mushroomed
.40S&W wall & gelatin 22" * no deformation
.40S&W† wall & gelatin 19.5" * slight deformation
12 ga. wall & gelatin 27.5" mushroomed
* these measurements do not include penetration of the 6" wall.
† CCI Gold Dot.
Summary
The 55 grain HP .223 has less penetration than any of the other ammunition tested. Based on the results of this testing, there appears to be no basis for concern regarding the overpenetration of the .223 [HP] round. In fact, it seems even safer in this regard than .40 S&W handgun ammunition.
The hollow point cavity in the .40S&W round filled with material when shot through the wall. This caused [these bullets] to fail to expand when they entered the gelatin. As a result, they penetrated 8.5" farther than when shot directly into the gelatin.
When the .223 [HP] was shot through he wall it began to fragment and as a result penetrated the gelatin only 5.5".
Because the .223 [HP] begins to break up on impact, it has less potential for damage or injury than the 12 ga. in the event of a ricochet. The .223 [HP] is obviously safer in an urban environment than the 12 ga. with slugs or buckshot.
Additional testing conducted proved that the .223 would penetrate a car door or glass. The .223 rounds fired into windshields began to break up after entering the glass and did not retain much energy. In most cases these rounds split in two.
