offtrail Member Lifetime Membership Jan 12, 2009 #1 What is the proper length of the apv cables on an 07 M8 Sno pro. And do you measure them in the up or down positon.
B buster888 Free Member Jan 12, 2009 #2 I believe it is 35mm. Measure exposed cable only. From bottom of barrel to start of cable casing or sleave.
offtrail Member Lifetime Membership Jan 12, 2009 #3 Is that measurement with valves up or down? Up would make the cable measurement longer
Dam Dave Well-known member Lifetime Membership Premium Member Jan 12, 2009 #4 The spring will pull them back, just make sure all the slack is out of them, 1.39 inch
offtrail Member Lifetime Membership Jan 12, 2009 #5 thanks for the help. I had a spec sheet but I didn't know if it was for the old 800 or the new 800.
RACINSTATION Well-known member Lifetime Membership Jan 12, 2009 #6 Yes, 34.8mm to 35.2 mm is the spec. 35 is just right!
