Well I too am shooting in the dark, bought a kit from dave and had a ton of questions, thanks SAP, and thanks dave for answering the phone. I just wish there was a close templet for the exit hole, and a set of instructions. I cant imagine his call volumn with selling kits with no instructions. I am starting with a sled that had a boondocker kit on there, so I have no heat shields and no air box stuff, anyone that doesnt have that video, needs some sort of order of sequence of events page & pictures. Is there nothing to get started with the RB3 , initial maps? Dave did say that the video was different that his kit and install some what. I get the principals of the install, its just the little things, like turning your spark plug caps around and leaving the bolt out, where to knotch the delta box for the header, where to mount the fuel pump, where the oil supply line goes, pulling the snap ring off the turbo snail so you can get the oil return tight, or get your spark plugs changed before you get the turbo installed, the washers needed to shorten up the throttle body clamps, how to glue the throttle body boots to to the motor and the throttle bodies with some rightstuff, whether to to wrap the header with header tape or not, or to wrap the down pipe with header wrap, and better block off plate for the tunnel holes/snow deflecter and what heat shields to leave in or out. I am going to sit down and put together a set of instructions for anyone that wants, with some medium size pics.
Jim
