Apex & K-mod...moving skid ^ 1" in tunnel?
A
Alaskan
I have an Apex with about everything done but a turbo and I'm trying to get the KMOD gen1 dialed in...Kevin has been good but I have a couple ideas and want your thoughts, experiences and opinions.
I want it to transfer more, right now I get 2" of transfer and the shocks are set up right! So if I move the rear tunnel mounting point up 1" will I get more transfer or less? Also will this effect the track approach angle and ski pressure and how?
If this works and I know some others have done it and been happy then what's stopping us from moving the front mounting point up 1/2" for a little better approach angle....thanks for your help!
do you have the coupler blocks on it? You could always take those off if you have them.
no coupler blocks
It doesn't have the coupler blocks and is not boosted, it is the "big guy" valving and spring and has the front Fox Zero pro.
moving up will help with transfer and ease of driving. But as soon you will put a Extreme on it, you will have too much transfert. Just be sure when moving it that the lug wont it the exaust pipe or Aluminium Casting in the back where the exhaust sit.
i've done it to mine , but i needed to put smaller wheel over the shock at the rear mounting point to let room for the 2.5 lugs, and i had too much transfert.
I have the PC on it and it hook up great just getting no transfer with the stiff azz center shock & spring.....if I back that off then I get to much sag in the suspension and more transfer....I will be moving it up an inch and trying it.
Thanks guys for your help
