V
vigorcs90
New member
No. I have other problems. I cannot get it to rpm past 6500 while on a dyno with no load. I have tried two different ECU'S replaced the CCU, pipe sensor, water temp sensor,tps, ETC, and a second boondocker box. I also had the Stator rebuilt. I removed the boondocker box and the charge tube and ran it that day. No change. I also replaced the fuel board. New plug wires. Fresh plugs and new stock reeds with OVS reed stops. Mag cylinder drop to 400 degrees and the motor surges like the power valves are opening and closing. During a test I held the halves open with no change. I have swapped coils and injectors from left to any right with no change. Every thing ohms out correct with the stator. Amy ideas?
