Most guys go the opposit way and put the 800 gears in the 1000.
This is the avenue Ill be going for next season as Arctic cat hasnt offered me any real help with the 8 belts I wore out in 780 miles. I made 3 different phone calls and the best they could do was just say take it to yer dealer.....
OUCH!!! Put vented panels on, gear it down, and find a good clutch set-up. One of our guys was eating belts on his 1000, after side panels and gearing it down, the belts lasted pretty good. There does seem to be a problem with the balance of the shifting of the two clutches.
On this subject, what is the gearing in these DD's?
I see 60/60 and 55 and what not, but if I'm not mistaken that is the the gear on the secondary shaft and the first gear/input gear for the planetary gear.
I also see the 34t input gear (sungear) but the number of teeth on the ring-gear is nowhere that I can see?
Anyone know? Same on all drives?
RS
For a good explanation of the gearing and ratio go to bd xtreme. com website.
100mph 102mph is max what you get with the stock gearing at 7900rpm..Would apreciate any thoughts/comments on the "total" gearing of the DD since I'm talking with a friend of mine about his M1000.
Max speeds on M1000? Clutch ratio? Any overdrive?
Thanks
RS
And it have 0,80 overgearing.
So I cant see no gain in putting a M1000 gear in a M8.The M8 needs to be turboed or so to get use for the M1000 gear.
Stock M8 gear have teoretical topspeed at 145kmt/90mph/8000rpm. x0,80 =72mph.So if you get track speed upphill grater than 72mph go for the M1000 gearing.But if geting 72mph trackspeed on a stock M8 then you might wont to gå for a better track...
