Anyone successfully removed grips and hand Warmers?
Grips are easy to take off and reuse, I get compressed air with a nozzle and stick it under the grip and blow them off while sliding them off. Works great, but warmers, I haven't had such luck. I usually end up tearing the warmer and it doesn't work.
I always save my heaters. Use an air dryer or a heat gun to remove them. You'll need to use some kind of glue to install them on your new bar.
For the grips, die hard poo is right : air compressor. Be carefull not to damage the heaters though.
Not bad
Grips ------ air
Warmers ----- did them in the garage with a fingernail under the outside corner and slowly worked it off, took about 2 min. They seemed pretty tough to me, the stickiness stayed on the Warmers and I then reapplied them to the bar after I corked them.
Start machine- turn Warmers on till they warm bar, then turn off sled. Remove grips and Warmers.
air for grips, hair dryer and patience for heaters, you can reuse them all day long... Just use a little spray adhesive if you think they lost too much sticktion.
