Anyone running higher than stock risers?
Check with Ole's. He can tell you if you will need cable extensions for any sled. Better yet he can tell you how much you can add without having to lengthen the cables, and will ship it right out at a VERY fair price.
www.olesmachine.com
One of the best mod's I've made to any machine I've owned......
heyhey
hey sledskiing, how much higher than stock did the powermadd 8" and pivot adapter net you?
Thanks,
PistonBroke
I put a 10" riser with the powermadd pivot adapter on my 07 Attak.Changed to mountain apex cables and hose and all works fine. Its about 3.5to 4 inches higher than the mountain apex. Would never go back either.
Just wondering if anyone has a taller than stock riser on their Apex? Which one and did you have to get cable extensions?
2 inch is all you can get with stock,we sell a 8 inch longer throttle cable,the other cables are long enough to another two inches.
I had no luck with the 2 in rox had the cable so tight set off the tors
powermadd 8 with pivot no extensions
I just duplicated this last night - looks like it'll work great. I did end up making a relief in the cowling for the throttle cable to run a bit more directly. wiring no issue, brake and e-brake no issue.
I likey these ape hangers. :p
