Anyone run rkt drop in and kurts gear down together
tatorsalad
I was just wanting to see if anyone has used them together i am going to do the rkt drop in and was thinking about gear down also
Rkt
I have not run the gear down kit but have run the drop in kits for years now, I am regearing my sled this year also, I see nothing but good things to complement both together as a setup. I think it will only make the di kits shine even more.
I'm gonna be running that combo this year. I agree with tinker that it can only make the DI kit better.
I just had the RK TEK drop in kit installed. I still need to get a fuel controller. RK TEK says they run the Boondocker control box but my mechanic is convinced the Power Commander V and Auto tuner is the way to go. I'm not sure as I'm a newbie. Does any one have an opinion on this? Supposedly the PCV with the auto tuner only takes one trip to get it set up and then it is spot on because of the Auto Tuner.
How has the Boondocker Box worked for you guys? Are you happy with it? Would you do anything different now that you're set up the way you are?
The elevation I ride at is 8000-1000 feet
I'm excited to try this upgrade out!
