Anyone know how to check the baro sensor
Apparantly it is an absolute baro sensor and ambiet air temp sensor in one. Still working on my goofy cold starting prob on my tubo pro. Don't think it has anything to do with the turbo kit.
Machine powered up, take a multi meter to pin 4 (white wire). Use paper clips to connect the sensor or wire if you don't want to shave the wire.
I saw 1.83v at about 1000ft on a bosch 3 bar, obviously it changes with elevation.
Take that sensor and add enough vacuum or pressure to it you can make the machine shutoff as your tricking the ecu.
