srxspec
Guys, all the 2008 models and the 2009 MTX model use the smaller upper a-arm sleave, you will need the larger sleave to install your Concept front suspension!
You can still do a 1/2 turn adjustment, simply remove the outer tie rod bolt and move just that heim joint a 1/2 of a turn instead of turning the whole steering rod.
Any issues with ski alignment since the curved tie rods require being turned a complete revolution each time? This is due to the curve and needing to position them for proper clearance.
