I have an empty ABS cannister and used trigger I need to exchange and would prefer local.
i 90 cant do abs. tried last year.
http://www.secondascent.com/
http://www.backdropsports.com/ .. back drop for sure.
Yes we can do ABS, BCA, and Snowpulse in order to refill a canister for BCA is quite simple. They do heat up a little and as they cool the preasure does drop a tiny bit but we can easily top it off for you. Airpoppoff I am sorry if you are a touch under on air, it is compressed air so it does vary a little up and down, we will be glad to help you out. We will let pop off your bag and will also show you the process of how it is done if you would like. We were trained by BCA and I assure you we have done them plenty of times. We do like to let them sit after refills to dissipate heat so it should take longer then 3 minutes so we reccommend that you do a little shopping while you hang out.
thank you,
thank you,
IF you want it refilled...you can go to any Scuba diving shop!
thank you,
Thank you, Since I'm from Yakima I'm probably going to buy a spare cylinder so I'll bring it in next time I'm by there.
Snowbi--- Dont you have to have an adapter for a scuba place to do it for you?
On another note some people have said fire stations will do it, I've contacted a couple locally in my area and due to their audit regulations they would not do it.
They do it for free. (BCA, not sure about ABS)How much to exchange trigger and cannister (ABS) at I90 Moto?
