I did, I took every friggen bolt apart on my pos D8 and parted it out...Oh, you meant "the fix"
Save yourself the time and money...
Put some extra oil in the tank each time you run it and drive it like you stole it...
I thought you might have some input!- SKIBREZZE-
We did one for a customer who was replacing a short block and then a friend of mine just did his. Neither sled has enough miles on them yet to really comment on how it works. The install goes fine although they recommend reusing the original base gasket and I think I'd change them both if you're doing that much work.
I agree about the bottom end potentially failing if left stock. I'm telling you, you will be happier when that thing is gone.
Put a Suzuki in it![]()
