Anyone have a sheet of engine codes on an apex?
Just bought a 07 apex with MCX turbo. Has around a thousand kms. on it. Took it for 2 passes across the yard, and went to load it in my trailer. Now it doesn't want to idle on it's own, once fired up it will run for a few seconds then start to dye out if you let off the throttle. The check engine light is on and the #23 is up on the display. number 14 flashed a couple times to, but not doin it now. Don't want to head into the backcountry until I know its working good. The coolant light was on so I filled it up and it is boiling out the extra, other than that I have done nothing. Any ideas? Thanks
Thanks guys, appears to be an issure with the atmospheric pressure sensor. I wonder if this has something to do with the idleing thing. HMMMM
On an 06 I would say the TPS is toast if it is the original one. The manual tells you how to by-pass. With pictures too.
Pulled er in the shop, wnaked off the panels and went in for supper. Went back out and fired it up and is 100% again, what gives? Now I am a little worried to take it out. Guess i'll have to see if it happens again.
I have a buddy with an M7 who had problems similar to this, but his was also running like crap. It was his atmospheric pressure sensor hose that was plugged with a little bit of water and it would ice up and clog. Locate your sensor and check it. It probably thawed out when you put in the garage.
Ya id say this was the same thing. I had it on my deck and was driving in the rain for a bi then it froze. Now all I gotta do is find the thing. Anyone know where the sensor is on an apex?
