Anyone had any luck straightening A-arms?
N
Dec 7, 2007
130
31
I bent a lower the other day, I have new aftermarket A-arms on the way. I was just seeing if anyone had any luck trying to straighten one out. If so, how. Thanks
tuneman
1,167
1,205
Minnesota
www.everettsports.net
Yes, I straightened one with lots of heat, a 20 ton press and water quench. It wasn't perfect, but I was able to finish the season with it. Bought Zbroz in the off season.
goridedoo
3,868
3,546
I straightened a lower that was bent pretty good... just used a press, cant even tell it was bent. I’m sure its weaker now, but I put another 400 hard miles on it and its held up.
SRXSRULE
2,512
1,592
YES. Have fixed several of them. same thing with bent suspension rails. I use a 50 ton press, but more for the extra space it gives you. You dont need a ton a force to do it. I dont use heat, just go slow and make sure its supported correctly so it only bends where you want it to. As long as you dont crack the metal you will be fine.
Cerialsledder
SnoWest Badge Maker
1,874
1,133
Sault Ste Marie, MI
I have fixed a few by using a press with a craddle jig that I had made up and lots of heat. I have access to a heat treat oven so I wasn't too concerned with the strength of the arm afterwords.
