Yes your sled will pull both weights exactly the same because your gain is through engagement to mid range. The top end at 7700-8050 is almost the same as stock. A couple dyno HP does not equal any weight pulling power and is mostly negated by setups. The dyno doesn't show you how much resistance factors like it does in the field or if you had a track dyno setup. JUST ANOTHER reason why guys should run the trimmed track. I get another gram to sometimes two over a non trimmed track at 7950 and the results on the field are plus 4 mph IE TOP END is even better. Stock tracks with this setup essentially act just like the stock head.
The real gain on this head is engagement to mid pull for you guys that run the non trimmed tracks. (it's conclusive that it is tip weight as every 1/2lbs added or subtracted from your track equals 1 gram or 100- 150 RPM)
If the poster would test his sled versus a consistent sample sled he'll find out that he gains 2 to 4 lengths consistently with 64 grams at 7950 versus 62 grams at 7950 - 8050. IT HAS NOTHING TO DO WITH PIPE SCAVENGE! DON"T MESS WITH YOUR PIPE CLAM SHELL! This setup is TUNED to operate at it's peak at 7950. Changing the tune of the pipe does nothing but start you over trying to find a high performance combo of clutch to transmission of power. This is the exact reason why guys can't find much performance in changing to an aftermarket pipe with the Polaris system.
Any doubts LETS RACE FOR MONEY
