W
Can you answer some questions?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First of all; Do you have to run Race Gas? Do they work better with twins or a single pipe? How much $$$$?
Thanks in advance.
Thanks in advance.
Can you answer some questions?First of all; Do you have to run Race Gas? Do they work better with twins or a single pipe? How much $$$$?
Thanks in advance.
I run a Trygstad 880 with pump gas and single aaen pipe,Y pipe and airbox mod.This thing flat cooks,The main jets are 600 with .020 on the needle and 15 pilots.Took awhile to get enough fuel to the motor, I am running this sled with turbos.impressive motor as it has a race crank as well
Is it in the XP chassis? Sounds cool. How much$$$>
Could it fit in an XP chassis? Does Trygstad have a website?
Thanks in advance.
Are you sure that Mohawk fuel is being used. It is an oxygenated fuel that should not be used in a mod engine. There have been 2-885's blown because the Mohawk crap was put in. Someone did Fred a favor and filled his sled up in the morning with Mohawk 94 2 weeks ago. He made it 2 miles before his engine squeaked. Fred was unaware that Mohawk fuel was used until he tried to figure out how it blew. That fuel burns hot. I burn premium Shell Fuel with 2 gallons of C-12 per tank for a safety factor. Fredw puts in one gallon of C-12 per tank. Even with the gallon of C-12 combined with the Mohawk Fuel his engine blew. Baker and Sheriff runs 50/50 with Shell Premium and Av gas. These engines will run on premium but the safety factor of race fuel is cheap insurance.
I've heard this Chevron thing before, but every weekend about 500 sleds fill at the one in revy so i'm not to sure. I fill there everytime i'm near revy.
As for the BB i ride with a guy who has one in an XP and it rocks, sled was set up by Baker.
I think low $2000's for the kit.
Cuso, He's right Chevron is Ethanol Fuel!!! We stopped using it last trip. Those bastards don't even tell you!!!!. I asked the clerk and she wasn't sure so the manager came out and told me yup it's 10% ethanol blend....
You sure it is Ralphs kit? If this is Danaluk's sled you are talking about, ask him about Chevron fuel. Oxygenated fuel & high compression 2 strokes ????
Rather misleading octane advertising. The problem occurs when oil is added (in the 2 stroke) you end up adding more oxygen then the already highy oxygenated fuel creating the lean burn down. Shell refines a truly Premium fuel that is highly recommended for 2 strokes.Ya its Ralf's kit no not Danaluks.
Well good to know the Chevron is like that cause they were chargin $1.42/L yesterday shells premium was 10cents less across the street.
Its only a matter of time before they are all ethonal/oxygenated so then what do we do?
FYI i am running high comp and advanced MPEM from the race department for tha last few rides, so far so good but don't like pistons anymore than the next guy so i'll try some shell fuel.
Revdawg
As for all companies using ethanol based fuels, each province will have their particular legislation mandating compliance, It will occur in BC long before Alberta....Revdawg i recommend throwing some 100 LL in with your premium if you are running some high compression. What are you at 13 to 1, 145 lbs? Better to be on the safe side. I run 50% in my XP. Just because.
Sheriff
Hmm interesting, i do premix so that might help a bit (40:1). I'm running 13:1 and usually 150-160psi on comp test.
I was running a a gallon or two of AV last year but so far this year the only thing i have burned is Chevron 94 (abou 30 tanks on it). I had some bad luck with shell here in alberata with high water content. ( had a Jerry can full with alot of ice in it.) Could be an isolated incident to that station though.
good info guys,
