R
redbarchetta
I installed an aftermarket can because of the excessive heat the oem one put off under the hood. Now i have burned my side panel from rolling the sled over when stuck probably on it side to long but the pantywaist side panel pushed in against the can and burned a hole in it. Even on the clutch side i have a rub spot from the primary probably from doing powder turns and snow pushing in on the side panel. Has anybody else had this issue and if so what have you done to fix problem.
