Any tricks to remove warning stickers?
Hey guys, I just picked up my new 13 Pro on the weekend and want to remove all the warning stickers. Is there any products that you have found work better then others or just a heat gun and some time the best way to go?
A heat gun will get everything off quickly... except the ones on the coolers.:face-icon-small-fro For the coolers the easiest thing to do is drain the coolant first lol. LOTS of heat and patience will get the bulk off, I then turned to "GooGone" to get the residue off.
heat them up with a heat gun (not to hot) peel them off and clean up with wd-40, that's what works best for me
Heat gun and goo-gone here as well. Seems there is a fine line between not enough heat and too much heat. Not enough heat and you get little bitty pieces, too much heat and the stickers melt and pull apart. Get the heat just right right and you get big chunks off or all at once even. And if you heat the sweet spot with the heat, you also take most of the glue residue off with the sticker.
I discovered a trick that can work well...if there is residue, take part of the sticker you just took off (if it's still sticky) and use that to take the residue off.
I used heat and goo-gone on the tunnel stickers too, but something I should have tried is to heat the glue residue that was left and use duct-tape to "dab" it off a little at a time. Might take a little bit, but a lot less scrubbing. That method worked very well for me when removing the insulation adhesive from the inside of the side panels. Not sure if it would work on the aluminum tunnel as well.
Edit: Looks like bobback beat me to it! Have fun:D
heat gun or a hair dryer if you don't have a heat gun handy. goo-gone or similar product. I've use parts cleaner or carb cleaner to remove residue from the tunnels as well.
For the stickers on the back of the tunnel, heat from underneath not on top.works way better
Use the ol ladies hair dyer, heat them up, start to peel them back, hold steady pressure on them peeling them back while your heating them. Once there hot enough they will peel themselves, let the heat do the work...
3M adhesive remover by far works the best for the leftover glue
