Any physics genius' out there?
Holy crap! And I thought I just had to pass physics to graduate!
I need a drink!!!
yes, the 1.1 was in meters. I appologize, when I copied and pasted none of the units followed.
Yep, everything has a gravitational force. You exert a force on the earth just as the earth exerts a force on you. So that means when you jump you actually push the earth away from you and when you are up you are actually pulling the earth up towards you. Because the earth is so large and you are so small, the overall effects is so close to zero its not worth calculating.
Physics suxs....
what till you get into relativity and quatum physics!!!!!!!!!!!!!
I've always been told that when the angle of the dangle, meets the mass of the ***, the thrust is constant. What I need to know, is if the thrust is constant, would this be considered perpetual motion?
Only if you factor in the coefficient of friction and if the tensile strength of the dangler is known.
Reading some of these previous posts made my brain itch!
I think compressive strength would be more of an issue here, you don't want that thing to buckle.
