Any one tried to put a long track on Z1 Turbo
M
modboy
New member
Just wondering if anyone has put a longer track on Z1 turbo or if you know what kind of clearance there is in the tunnel,if you could put a 2 inch track on
One thing to check would be the diameter of the drivers compared to a M. My guess is the M drivers are smaller and would help with the clearance up front with the taller lug track.
A '07 flatlander 136" http://www.hardcoresledder.com/forums/index.php?showtopic=300759
index.php
According to the part numbers, the M uses an 8 tooth, 3" pitch driver, the Z1 uses a 10 tooth 2.52" driver.
That gives the M a 7.64" diameter driver, and the Z1 an 8.02" diameter.
So the M would have ¼" more clearance in the same tunnel, but I don't know the stock clearances, so take it for what it's worth.
