Any issues with a 2012 Pro 800?
R
redbull660
I may have found local guy here that selling a 2012 pro with 1700 miles on it. If I buy it do plan on doing the top end just because its the way I am. Sled is in excellent condition. I guess these are the chain instead of the belt drive.
Put a "fix it kit" in it or an Indy specialty long rod kit in it and ride it.
Do the 2012 pro's have the same suspension as the 14's? Are they the same width in the front? I have two 14 pro's and like the way they ride and wanting to get this 2012 for my son.
Same geometry-- front shocks are slightly shorter because they are mounted a little higher on the aluminum casting.
Front and rear track shocks are the same.
If you like 2014 handling, you will like 2012 handling. Install a spacer and longer piston and ride it.
Clarifying point - the 13-15 pro's have the shorter front shocks. All non-pro RMKs (aka "standard", 11-15, with steel a-arms, and 11-12 Pros, have the slightly longer shock length. In 15, there were snowcheck non-Pro RMKs with bonded a-arms, not steel, that came with the shorter front shocks. If the a-arms are steel, the shocks are longer.
Of course, Assault's are another case altogether. Can't mix and match with them, either.
