I have mine already, it is definately wider than the original.
should eliminate the deflection problem.
Please post some pictures and part #'s !!
How wide is it ?
The new belt is 1.5" wide.
They are out and going as fast as they receive them # 417 300 377 got mine TODAY
There is a thread on dootalk that states they have started shipping them.
Going out this morning to break in (2) of the 377 belts, and 1 new motor.
Will report back.
The 377 is much stiffer and wider, 1-7/16th inch on top1-1/4 inch on bottom, 17 inchs inside span if you pinch the belt together in the middle.
Throttle response should be quicker with the thicker belt, no !
only got to ride 20 miles, belt seemed to grip VERY well, I may be imagining things, but my throttle reposonse seemed MUCH quicker as did Snojo's. We put about 35 miles on her's, and her's seemd snappier also, got to full pin Snojo's , WOW! so far so good. However.............
I had major damge, see my post in the doo section.
The problem is that Doo went with a piss-poor calibration that doesn't provide enough side force to grip the -166. So instead of going to the trouble of adding a little weight and a progressive helix they are just going with a different belt that will cost more and probably only fix a handfull of the problems. Then those that have PROPERLY calibrated their clutching to make the 166 work AWESOME will be spanking the sleds that only throw on the new belt and those people will still complain that they are getting spanked.
