Antifreeze in exhaust?
Just got back from the Horns. Sled ran great the whole time it's an 04 800 has about 500 on rebuild. The last day it started smoking when I started it and smelled like antifreeze. Sometimes the temp light would flash for a few seconds after starting it but then seemed fine. Any thoughts on where to start first? I'm thinking check the head gasket first.
Thanks
Justin
O rings in head not good to run with leak had a rod bearing go bad right after anti-freeze leak, thinking it washed oil off rod bearing.
check your o rings, I lost one before and it will take out your rod bearing, coolant is very abrasive
