Clipping is more important for hifax wear and if you use hyperfax.
What is best tool to use when cutting these windows out? Something from like a local hardware store maybe?? Do they have to be cut as a square or will just a round hole work?
Takes about 30 min to punch out the closed windows with a drill and a hole saw. I have run anti-rachets on several tracks done like this with zero issues. A turbo with 250+ hp maybe you would want square holes and all clipped. I'm only running about 180 hp though and don't have problems.
So the teeth on the hole saw doesnt tear up the track at all?? This sled is an all stock motor 700.. everything else has been modded, but the motor is stock..
