M
milo303
Diagnose away!
Hit det one time a couple tanks of gas ago and immediately after re starting from that det cycle I can't pull over 7900 and it cuts in and out to exactly 6600 rpm. The sled is clutched to run about 8300 at altitude (Colorado)
Sled has a drop in kit with about 500 miles on it with recently found (post det) scuffs intake side of the pistson. Ran amazing up until this det, compression is good
New plugs, new reeds, new plugs and caps, new fuel filter 500 miles ago this fall, just re adjusted the tps and it seems fine... 1800 rpm and reverse works.
Just for giggles I tossed 3 gallons of av gas in to see if it would clear out the bog and no dice
Switched the ethanol chip back and fourth with no results
pulled pto power valve, it looked fine as well as exhaust side of piston and rings
Looked in both spark plug holes and pistons look fine, pulled plugs post det looked fine also but I changed them anyways
I am friggin stumped.. A couple people suggest a plugged fuel filter.. I can check it but I just have a hard time swallowing that with it happening right after a det bomb but who knows
Oh and no rubbing wires either
http://youtu.be/Bs8xQEC1fOI
